Replace antenna base?
Anyone know how to replace the plastic base of the front, mast antenna? (2021)
https://www.fordpartsgiant.com/parts/ford-aerial-without-cable_av1z-18813-a.html?vin=&make=Ford&model=Transit Connect&year=2021&submodel=&extra1=&extra2=&filter=()
Mine has cracks in it. Getting water dripping through the housing for the windshield's sensors. I thought it was from a bad glass seal. While caulking I found the cracks. Caulking didn't help...
Posted (edited)
Was able to access the nut via the dome light opening. The nut conveniently stayed connected to the wire which made reinstullation quite easy.
Unscrewed the nut with an 8mm deepwell socket. Popped the old base off, from the outside, and clicked the new one back on. Reattached the nut from the inside. Easy...
The old one was definitely leaking.
Edited by BSJBSJ
