Jammin1 Posted January 4, 2023 Share Posted January 4, 2023 I bought a 2011 transit connect and all electric doors locks where not working correctly. Door agar switch and wouldn’t lock. To replace all door latch assembly’s would have been close to $1500. That was unacceptable. The door agar problem I just jumped the two wires together. Van thinks door shut all the time. Turned out the door locks have a tiny motor inside every door latch assembly. The motor was just used up. I replaced the motor in every door at a cost of $7 each. Problem solved. Even the sliding door I fixed. Much harder to get to motor but doable. Bought motors new off eBay. Hope this helps someone out https://www.ebay.com/itm/203176710226?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=IUqhQx04TQe&sssrc=2349624&ssuid=kZOfkNhuR--&var=&widget_ver=artemis&media=COPY BSFixFTC, Don Ridley and lowspeedpursuit 3 Quote Link to comment Share on other sites More sharing options...
lowspeedpursuit Posted January 5, 2023 Share Posted January 5, 2023 Sick; I have to do this soon. Don't suppose you took any pictures of prying the slider lockbox open? ThatsMyDawg 1 Quote Link to comment Share on other sites More sharing options...
lowspeedpursuit Posted January 7, 2023 Share Posted January 7, 2023 (edited) Okay, following up with pictures/disassembly steps. Similar "one slider wouldn't power-unlock" problem to OP; installed a junkyard door that also does the same exact thing. Hopefully it's a coincidence, the motors are my problem, and not the computer not spinning it for long enough or something. The lockbox/latch assembly is held into the door with 3x T30 screws by the latch. The door card/trim pops off, you pull out the manual lock toggle on the inside of the door, and the box falls down. Remove the inner and outer door handle cables and undo the trim clips along the wiring. The box looks like this: You need to pry the sides away from the "top" at the top and bottom of my photo to clear the 4 tabs. The 5th tab, on the diagonal, you want to pry up on the "top" to get the tab to start straightening out, then bend it all the way straight and clear the slot. All the guts will be attached to the "top half" of the case as it's laying in this photo, and the other half, which the sides are part of, is a cover you can set aside. Flip it over and you're looking at the gearbox. Take out the 4x T15 screws and pry it open. So the worm gear motor spins the small gear, then the big gear. A tab on the bottom pushes against the silver clockspring to return to center. The tab on the top interfaces with the white lever in the first pic, which eventually actuates the lock. PN on the motor. Top number resolves to a number of listings like OPs. Since all the options I could find ship from China, ETA is 01/19-01/26. I'll follow up with whether the motor fixes my power lock. Edited January 7, 2023 by lowspeedpursuit fix pic BSFixFTC 1 Quote Link to comment Share on other sites More sharing options...
StephenC Posted June 30, 2023 Share Posted June 30, 2023 Thank you SO much! This totally worked. 3-4 hours and I'm no pro. Found the actuators on Amazon. Fixed two sliding doors. Now onto the one front door... which is def more involved. Quote Link to comment Share on other sites More sharing options...
ThatsMyDawg Posted November 10, 2023 Share Posted November 10, 2023 (edited) On 1/4/2023 at 3:08 PM, Jammin1 said: I bought a 2011 transit connect and all electric doors locks where not working correctly. Door agar switch and wouldn’t lock. To replace all door latch assembly’s would have been close to $1500. That was unacceptable. The door agar problem I just jumped the two wires together. Van thinks door shut all the time. Turned out the door locks have a tiny motor inside every door latch assembly. The motor was just used up. I replaced the motor in every door at a cost of $7 each. Problem solved. Even the sliding door I fixed. Much harder to get to motor but doable. Bought motors new off eBay. Hope this helps someone out https://www.ebay.com/itm/203176710226?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=IUqhQx04TQe&sssrc=2349624&ssuid=kZOfkNhuR--&var=&widget_ver=artemis&media=COPY I searched a few times, but I see no such motors. Since the original post is so old the link is no longer good. I see now you aded some pics, so I will do some searching to see what they cost now and how available they are. Thanks.. Edited November 10, 2023 by ThatsMyDawg Quote Link to comment Share on other sites More sharing options...
lowspeedpursuit Posted November 10, 2023 Share Posted November 10, 2023 1020098 Motors Ebay Amazon Quote Link to comment Share on other sites More sharing options...
braddd Posted February 5, 2025 Share Posted February 5, 2025 (edited) Quote This is a huge help! $40 and 4 hours later, I finally have all my doors locking when I push the lock button. I had been walking around the car and checking each one and locking the ones that failed to lock manually every time. I thought I was going to have to bite the bullet and purchase entire locking mechanisms for every door. Edited February 5, 2025 by braddd Quote Link to comment Share on other sites More sharing options...
HoVISss Posted February 11, 2025 Share Posted February 11, 2025 Hi Brad, I am having the same issue and going to try replacing the motors. Which ones did you order ? Many thanks. Quote Link to comment Share on other sites More sharing options...
