Wet Front Seat Belts/B-pillar
Beer Box
  • 1 year later...
With the factory bolts and rubber washers in place on my roof I never had an issue during the first winter of ownership. My experience with wet front seat belts is directly related to my installing a roof rack. If this applies to your situation, you will need to make sure that the threaded attachment through the roof panel is completely watertight. If the mounting kit that you have for your rack does not provide a weathertight connection and you cannot employ a rubber washer to make the seal, you could use a healthy dab of Dow795 silicone on the threaded stud to ensure the connection is 100% weathertight. I have done this with complete success.
