How do I replace the ciarette lighter and aux port in my 2010 Transit
jmarino
The panel the lighter and aux port are mounted in is called the "Selector lever trim panel". It is the panel that surrounds the shift lever. You will need to lift up the rear(the edge toward the hand brake)of the panel to release the clips. Once the rear is released, pull the panel towards you to release the front clips (behind the lighter and ventilation control). You do not need to remove the front (temp and fan controls) or rear(handbrake and cup holder) console.
