Transit Connect MK1 2009 Fuse Box Diagram
I own a Ford transit connect 2009 1.8tdi, awhile ago we took the van into a garage went in for limp mode which was fixed but the interior fan/blower didn't work 1 to 3. we still had 4 so couldn't be bothered dealing with the garage again,  yes you guessed it now it seems that fuse has also blown so now I don't have anything and I can't find the location of that fuse.
I've looked anywhere and can't seem to find this fuse key.  I can find plenty fuse boxes for sale but no list.  I know the part numbers it's listed under are 518774302 & 2t1t14a073ac
The few searches that came back had the same problem as me, others advising it's not the right sticker for the fuse box.  I found a couple of forum posts that said that attached correct index but nothing was there.  the only thing I found was a list some user had typed up.
Does anyone have the index that they could send me. i will attach the fuse box and the index attached with is said to be incorrect.  i don't want to start pulling fuses out when i don't know what's what's.
are both fuses in the glovebox or one in engine bay and one in glovebox? even if someone could mark on the diagram which fuse is the heater any help would be appreciated.
