Remove bulkhead and reconnect middle seatbelt...?
33Senior
I don't have a Connect, yet. But I understand that on the models that have 3 seats up front, the end of middle seatbelt is attached to the bulkhead. If I remove the bulkhead, is the seatbelt able to be reattached? To the chassis, or maybe the seat itself? To keep the belt in use and pass an MOT.
Cheers
  • 1 year later...
I have removed the bulkhead and I am getting a 40mm square tubing frame built and fitted across the floor and roof and down where the seatbelt bolts onto (side ways H if that makes sense). Will help with the structure of the van too but I know that the bulk heads can be removed and still be safe.
  • 5 months later...
I’ve had my bulkhead removed, had the MOT tested with seats down to pass.
DanielH  do you have pictures of the frame in place? Did the MOT Pass? Would be nice to have the third seat back.  Was the frame Build and install very costly?
