Trying to replace the broken grill emblem
I had to replace the upper and lower grille because they were all broken as I was replacing my fogged headlights.  I bought a new emblem and retainer, but the spring is not being made right now and all the dealers are out. So, I’m trying to reuse the spring that I got off my old one.  I can’t seem to figure out how the spring goes together with the emblem (from the front or back?) - also, can’t figure out the proper position of the spring on the guide that slides through the hole in the grille. I tried pulling it way down on the guide, only down to the notch that fits in the grille and I’ve also tried to put in through the other side and can’t get it to go all the way in. I figured out how to connect it to the retainer, that was easy, but the other end is a mystery to me. Any ideas?
