lights on when engine is on
Is there any way to turn off the exterior lights while parked with the e brake on ? I work in some pretty bad parts of brooklyn and Queens and if I want heat or AC the lights sometimes attract attention .
The only idea that comes to mind is to pull the relay for the Daytime Running Lights (DRL). it will take about 30 seconds. The relay location is in the DRL postings. If you can live without the DRL's. It is not an idea that you would want to do every day!
