2008 TC fuel line/injector issues
drummerbecca
Hi all. I'm new here and just signed up in the hope that someone might be able to help. I have a 58 plate transit connect which I believe is a 1.8 diesel. Since I've had it, I've had a huge issue with the fuel line continuously popping off the injector while it's in use and under pressure. After multiple replacement fuel pipes and a complete change of injectors from a donor van, this hasn't helped at all. The line seems to disconnect from the same injector every time (number 3), but it seems unlikely to be the same issue with 4 different fuel pipes and 2 sets of injectors. Can anyone tell me if there might be something elsewhere in the fuel line that might be causing extra pressure at that point and causing the pipe to pop off the injector? I'm new to all this so apologies if it's a stupid question. Thanks, Becca
