Karl W Posted August 2, 2020 Share Posted August 2, 2020 having a 2003/2004 transit Connect 1,8 di . trouble is like this : if i try to start as usual and let it glow before turning the key , engine cranks but not start . if i turn key very quickly engine starts and run for 1,5 second , if i keep Accelerator pedal half way Down , and turn key quickly and keep on turning the key on and of fast i in a way keep the engine running . when doing this for a while some times the engine starts working like normal and keeps running , i can drive for as long as i like but NeXT time trying to start it is all the same and the problems is there again ,. ill changed the crank position unit , it did not help at all . some months before this happen the engine start to have rough idling from time to time , if i tapped the Accelerator pedal it starts idling normal againg . it seems like it was getting worse and worese and i noticed when slowing Down to a lover speed limit the car was in a way jerking a little . any suggestions to where the problem might be ? Wiggo Quote Link to comment Share on other sites More sharing options...
