windshield washer diagram
Washers not delivering fluid, pump working, fluid showing in reservoir.  No fluid at nozzle when disconnect hose. Hoses disappear inside the driver side fender:
How many parts do I need to dismantle to get at the hoses and diagnose this?  Is there a diagram of the routing?  I find only the parts diagram, which does not show the body of the car or surrounding parts.  Anyone messed with this before?  Seems like an expensive reason to have the dealer try.  And my local dealer service is terrible...
  • 2 years later...
I had the same problem with my new-to-me 2016 TC. I removed the left front tire, removed enough screws/fasteners to pull back the front of the inner fender, and could see the pump on the bottom of the reservoir. The hose had simply come off of the barb on the pump. Pushed it back on, and voila, everything works! I'm not sure why the hose came loose, but at least for now, I'm back in business!
