growler1550 Posted January 8, 2012 Share Posted January 8, 2012 Hi Guys, This is my 1st post so please bear with me.. I have a ford transit connect tdci 2007 & I am having a right night mare with a disesl leak in the engine!!! basically the return pipe at the injector is acutally forcing their way out from the injector when running hence causing a drip from the bleed back pipe I can hold the leaking one in with a flat scredriver but it then moves to the next injector I have blown out the return lines that go back to the filter & these were clear & tried the engine again & same trouble for some reason this is only happening on 2 injectors Any ideas on what I can do?? Thanks guys Andy Quote Link to comment Share on other sites More sharing options...
