murfeey Posted October 23, 2019 Share Posted October 23, 2019 Driving home in van the other night heater started to blow cold warm air then cold now it doesnt get hot at all,engine runs to temp sits at halfway on the gauge, ive replaced the thermostat and its had a new rad fitted with new coolant ran up to temp no air in the system ,i can drive the van for 30 mins to wrk both rad hoses are hot, local garage has suggested water pump oil cooler and matrix, so next question , where to start. as an 06 van does the dash need to come if its the matrix, i see the oil cooler is 2 pipes and 4 bolts and ive done a water pump before. any advice cheers murf. Quote Link to comment Share on other sites More sharing options...
