Starter Problem
fishaggregator
  • 2 years later...
Hiya, did you get any answers to your problem??? I have left my Connect standing for a few months and thats all I get from mine as well...... New battery didn`t make ant difference either....Let me know if you solved it, Thanks , Dave
Hello dbarr2, "A few months" is the key to your problem, at least it would be if you were in the US. It is an easy fix so try it. Here in the US, if the Transit Connect is not started for over 50 days, the engine management computer is programmed to shut down! The fix is to remove your battery for over 2 minutes, then re-connect it. That resets the timer on the computer. Give it a try and good luck!
