Klingon Posted February 11, 2019 Share Posted February 11, 2019 I've had my 2013 XLT TC wagon for about 5 days now. I came from a 2005 F350 Dually Crew cab Lariat longbed w/ literally 3 times the cubic inches of my TC. That being said, it's been an easy transition. Just need to remember to apply about 80% less pressure to the brake pedal unless I want to go through the windshield. I did a bit of research before buying. Like many said, the 4 speed trans. is a little clunky and dated. The engine is weak but I expected that and accepted it ahead of time. The driving experience is that of an early 80's econo-box.....like a Reliant K or any other early American FWD. I know that doesn't sound very complimentary!! But, as long as it keeps running I'm a happy man. I got second row seating which was a must have. Body has a few dings but nothing bigger than a dime . I paid $8500 w/ 72,300 on the odo. No major issues that I can see and I used to be a mechanic (a lifetime ago). Minor issue: The dash says there is a door open but there isn't. The doors also wont lock either w/ the key fob control or manually (I turn the key in the driver's door lock and all the doors click locked....then a half second later they all unlock. I'm assuming the two issues are related. Never been in an accident. All the door close straight and smooth. Must be a sensor. Any suggestions. Also has check engine light on. Auto parts store threw a code scanner (if that's what it's even called) on it and said it had a bad O2 sensor. Easy fix? Location? Tire pressure warning light is on and will be until I figure out how to disable it. It came w/ 215/70's on the back and they aren't XL rated. Max. psi is 44 which is what I have in them. I'm not hauling anything more than 120 lbs. of kids so I'm going to run them down and later replace w/ XL rated or maybe even C1 or C5's. Till the....44 psi. Definitely louder on the inside than I thought a modern vehicle would be. I know....it's primarily a utility/work vehicle. I don't get the impression that anything is wrong. Just a bit more engine noise and vibration than expected. Is this par for the course? Any advice about what to look out for on my TC would be appreciated Quote Link to comment Share on other sites More sharing options...
