2016 TRANSIT CONNECT CAMPER VAN, SOLAR, 28 MPG FITS IN GARAGE
Brand New Campervan Conversion on a like new 2016 Ford Transit Connect. Bumper to Bumper Warranty!
2016 Ford Transit Connect Campervan
Model Year: 2016
Make: Ford
Model: Transit Connect
Color: Magnetic Metallic
VIN: NM0GS9F74G1252966
Mileage: 23,800
NEW Campervan Conversion by DLM-Distribution
CAMPER VAN FEATURES
-Bed: 72 x 40 slide out bed with high quality/ high density very comfortable 4" foam with dunbar steel (grey) cover.
-Cabinetry/ shelfing with flip out table matching factory grey interior
-LED overhead lighting and shelf lighting
-Privacy - Blackout front window privacy curtain included. Easy to install and use for privacy or heat control for parked vehicle when not in use.
-Limo tinted rear windows provide one way privacy glass. See out but not in.
-Vehicle auto start capability by temperature. Programed to check interior temperature every two hours, if temperature goes above 72 Degrees engine starts to run AC cool unit down and shut off in 15 minutes automatically (feature can be turned on and off as needed)
-Roof Fan, 10 speed reversible with built in thermostat. Can be open when driving and or when raining.
-100Watt Solar Cell with digital controller/ monitor
-120V power outlet with built in USB ports
-Side window mosquito screens
-Camper starter kit: multiple totes for storage under bed and on shelving, Single burner portable stove w/fuel, water jug with on/off spigot, wash basin
-Rear air ducting and vents with airflow controls for engine run air conditioning and heater
-400W Power inverter with USB ports and two 120V outlets
-120 to 12V converter w/4-stage smart charger
-High end AGM house battery- 55ah
-Shore Power plug- 15amp service
-Refrigerator- 24 Quart settable between -8 and 50 degrees F
-Interior- Custom Camper Conversion trimmed with factory greys and black
-Cloth headliner
-Overhead front storage shelf
-Remote start- two way remote lets you know when vehicle starts, how long it has run, how long it will stay running and interior temperature.
With plenty of room for two this campervan is like no other! Standard with Solar power to keep your house battery charged and refrigerator running without hook ups. Outstanding LED interior lighting, limo-tinted windows provide one way effect- See out but not in. Front privacy curtain which can also be used as sun shade when parked and used as a daily driver. Solar/Battery monitor system provides plenty of power along with the status of your house battery. 120V shore power outlet with USB charge ports for shore power use. 12V access/port which runs from house battery, inverter for "off-grid" 120V needs. (400W max) High end easy to clean and maintain vinyl flooring, easy access under bed storage and rear cabinet storage for your outdoor cookware, bags and travel necessities. Low maintenance and easy to use campervan! Remaining 3 Year 36,000 mile bumper to bumper Ford warranty and 5 year 60,000 mile Ford powertrain warranty. Full 12 month conversion and camper systems warranty. Side window screens provided for bug control and ventilation when camping. Refrigerator is 24 quart highly efficient compressor driven with the ability to set temperature from -0 to 50 degrees F and maintain it for safe food and beverage storage. Refrigerator will hold the equivalent of 27, 12 ounce cans and can hold a 2 liter bottle upright.
This 2016 Ford Transit Connect Campervan is just: 79" high (with roof features) and 189.7" long- Fits in standard 7 foot garage and can go through any drive through car wash!
BASIC VEHICLE SPECS:
Trim Level: Wagon XLT LWB
Body Style: WINDOW VAN
Engine Type: 2.5L L4 DOHC 16V
Transmission-short: 6A
Transmission-long: 6-Speed Automatic
Driveline: FWD
Tank: 15.80 gallon
Fuel Economy-city: 21 miles/gallon
Fuel Economy-highway: 29 miles/gallon
Anti-Brake System: 4-Wheel ABS
Steering Type: R&P
Front Brake Type: Disc
Rear Brake Type: Drum
Tires: P215/55R16 97H
Maximum Towing: 2000 lbs
50 state emissions
VEHICLE FEATURES:
16 Inch Wheels
4 Speakers
4-Wheel Disc Brakes
AM/FM
Adjustable Steering Wheel
Air Conditioning
Anti-Lock Brakes
Aux Audio Adapter
Braking Assist
Bucket Seats
CD (Single Disc)
Cargo Area Light
Center Console
Clock
Cloth Seats
Cruise Control
Driver Adjustable Lumbar
Front Floor Liners- Weathertech
Fog Lights
Front Airbags (Driver)
Front Airbags (Passenger)
Front Bucket Seats
Front Side Airbags (Driver)
Front Ventilated Disc Brakes
Front Video Monitor
Front and Rear Stabilizer Bar
Full Size Spare Tire
Heated Mirrors
High Performance Tires
Illuminated Entry
Independent Suspension
Intermittent Wipers
Keyless Entry
LWB- Long Wheel Base
Low Fuel Level Indicator
MP3
Passenger Sensing Airbag
Power Locks
Power Mirrors
Power Steering
Power Windows
Privacy Glass- Factory
Radio Data System
Reading Lights
Rear A/C Controls
Rear Air Conditioning
Rear Air Ducts
Rear Head Airbags
Rear Heat Controls
Rear Side Airbags
Rear Window Defroster
Rear-View Camera
Semi-Independent Suspension
Side Airbag
Smart Device Integration
Speed Sensitive Volume Control
Stability Control
Steel Spare Wheel Rim
Steel Wheels
Steering Wheel Controls
Super Ultra Low Emissions Vehicle II
Tachometer
Thermometer
Tire Pressure Monitoring System
Torsion Bar Suspension
Traction Control
Urethane Shift Knob Trim
Urethane Steering Wheel Trim
Vanity Mirror/Light
Wheel Covers
Contact DLM-Distribution ~ Campervans today at 651-285-7089 or 507-382-9446 for more information.
Ask about financing, trades and delivery or pick up logistics.
On sale by DLM-Distribution of Lake Crystal MN / 651-285-7089 / https://www.dlm-distribution.com
Edited by transitseatman
