interior dimensions
do any of you know if the 2017 transit connects and/or connect wagons have the same interior dimensions as other years of the same make/model? i'm curious to see if there is one with either 69" with above the rear wheel wells, or one with sufficient diagonal length between the side walls, rear door and back of mid seats (while rear seats either retracted or removed) for use as an occasional sleeper berth.
