Kiss Lacika Posted March 30, 2016 Share Posted March 30, 2016 Skid Plate Ford Transit Connect 2013 - 105 £ Technical specifications:Sump guard for the protection of the: engine, gearbox, radiatorMade out of 2 mm thick steel plate.Screws, nuts, clips, all fastening accessories are included.Against corrosion all sump guards are powder coated.The exterior of the sump guard is provided with steel reinforcements, which increases the resistance to impact.Installation:Delivered together with the mounting scheme, that will describes the position and order of the accessories used during the operation.Every car is equipped with factory screw holes for fitting the sump guard, so this operation is extremely simple. It can installed by you, or at any auto service.For fitting your sump guard you don't need any mechanical interventions on the vehicle structure.Guarantee and handling of the car are not affected.The advantages:Increased resistance of impact and to various objects on the road.It covers the front compartment of the car, so the engine is more protected against dust and dirt.Higher lifespan compared to sump guards made of plastic or fibre glass.If you are not satisfied with the quality of our products, you can return it within 14 days.Warranty:24 months warranty offered. Site: www.sump-guard.co.uk Email: info@sump-guard.co.uk Tel: +44 7472 312326 Quote Link to comment Share on other sites More sharing options...
