3lucky33 Posted July 24, 2010 Share Posted July 24, 2010 Doea anyone know how I might be able to tow my Transit behind my Motor Home wthout the use of a dolly? Can I just put the transmission in nuetral or to I need a transmission pump? Does any manufacturer have a transmission pump available? Does any manufacturer have a base plate for mounting the tow bar? The Ford Transit is one awesome little vehicle and I know that towing it behind my motor home will give me extreme flexibility. Thanks, T Quote Link to comment Share on other sites More sharing options...
james3 Posted May 28, 2012 Share Posted May 28, 2012 I want to do the same thing. Did anyone ever answer your question of using a dolly or tow bar? Quote Link to comment Share on other sites More sharing options...
103west43rd Posted May 28, 2012 Share Posted May 28, 2012 As per page 154 in my 2010 Owners manual....... RECREATIONAL TOWING Follow these guidelines if you have a need for recreational (RV) towing. An example of recreational towing would be towing your vehicle behind a motorhome. These guidelines are designed to ensure that your transmission is not damaged. Note: Put your climate control system in recirculated air mode to prevent exhaust fumes from entering the vehicle. Front Wheel Drive (FWD) vehicles with automatic transmissions: Do not tow the vehicle with the front drive wheels on the ground. It is recommended to tow your vehicle with the front drive wheels on a dolly with the transmission in N (Neutral) or with all four (4) wheels off the ground on a car-hauling trailer So much for towing in neutral. Quote Link to comment Share on other sites More sharing options...
