2013 Focus ST Recaros seats into a 2010 TC - plug info?
deaster
Hi- Anybody know if the airbag & seat belt plugs/connectors (under the seats) are the same on a set of OEM Recaros from a 2013 Focus ST as a 2010 TC?
I realize the mounting points are different on seats & a custom adapter will need to be fabricated, but have yet to be able to find any info regarding the two plugs mentioned above. I also realize I would then need to create a wiring harness for both the power on the drivers side seat & the heated seat switches/plug under the seat.
Thanks
