2phast Posted June 22, 2013 Share Posted June 22, 2013 Hello. I am in need of the wiring diagram for a 2012 Transit Connect auto dimming mirror with backup camera display. I do have a diagram for a 2011 model, but the wiring colors listed are not the same as the 2012 model. The 2012 model has five wires; green, brown, black, grey and beige (solid colors 2012 vs. multi color for 2011). Any help would be appreciated. Quote Link to comment Share on other sites More sharing options...
103west43rd Posted June 22, 2013 Share Posted June 22, 2013 Hello 2phast, the 2012 wiring diagram is posted here......http://www.google.com/search?q=2012+ford+transit+connect+wiring+diagram&tbm=isch&tbo=u&source=univ&sa=X&ei=lrDFUe7CMqTE0QGj54HwAg&ved=0CDgQsAQ&biw=1264&bih=582 Good Luck! Quote Link to comment Share on other sites More sharing options...
2phast Posted June 23, 2013 Author Share Posted June 23, 2013 (edited) Hello 2phast, the 2012 wiring diagram is posted here......http://www.google.com/search?q=2012+ford+transit+connect+wiring+diagram&tbm=isch&tbo=u&source=univ&sa=X&ei=lrDFUe7CMqTE0QGj54HwAg&ved=0CDgQsAQ&biw=1264&bih=582 Good Luck! Thank you for the reply, but I have already done plenty of on-line search's and the 2012 diagram is not there. Plenty of other model Ford diagrams, but they are not applicable. I need the diagram from the 2012 green cover manual, or at least if someone could look up the diagram and tell me what the five wires go to. Should be switched 12v, ground, NTSC +, NTSC - and a reverse engagement (for the screen in the mirror) Edited June 23, 2013 by 2phast Quote Link to comment Share on other sites More sharing options...
