2012 tramsit connect gas powered (code p1000) nightmareeee! :)
952jzget
Hey guys seems like there is light at the end of.the tunnel lol,
Here are parts that have been replaced
Throttle.body
intake manifold
Pcm
And basically front end body parts (these were the first to.be replaced as the van is a salvage title, was in a front end accident.
So heres the story purchased it at an.auction, had front end damage, originally I.thought only the body parts had to be replaced and painted that wasntt the case once we removed all thee body parts to see behind in the envine compartment, so.basically had to replace all the parts that I mentioned amd now.im down to.the pcm, it sas sucb a pain in the ass figuring out my pcm was damaged from the accident (pcm had crack on the rear side not.visible, as the airbox was pressed agains it)
Originally my scan tool was shooting me that all major sensors were faulty, egr, o2, map, maf,etc etc, keep in mind this is the original PCM but I thought to myself this van only has 16k miles lol, the van would start up but it wouldnt move I would step on the gas but it seemed.like the fuel was not flowing as soon as I would feed it gas it would turn off Iidle was rough. changed the throttle body as.it had a crack that didnt work, we moved to the intake manifold and found another leak had crack on the rear side of the manifold replaced it and nothing stil wouldnt move, by this time its been about 4 months and.kinda tired.of this.thing I.finally decide to remove the pcm and BAM had a crack on the bottom side of it this is why the pcm is shooting me all these codes.lol its going crazzzzy.
So i decide.to buy another pcm matching numbers and.everything, I even switched the ignition and key,.so.basically I.have a new pcm with matching ignition amd.key, but.now it dossnt even turn on its.getting power I.can hear the fuel pump turn, dash is lit up, its getting power but engine doesnt fire up, I hooked up my scan tool (Maxidas DS708) and now the only code its shooting.me is p1000??
This has to be the last issue any help would be appreciated very much.
