Bug Man Posted May 9, 2013 Share Posted May 9, 2013 The display in my 2011 TC the display shows Distance To Empty as the default. Due to mounted equipment I cannot see the other clock on the radio while I drive. I can press the button and see the time but then it reverts to DTE. I would like to have the CLOCK displayed CONSTANTLY and the DTE be the optional display mode, visible only when pressed. I feel confident this must be a simple fix but the dealer had no clue. Any help? Thanks! Tom The Bug Man in Rhode Island, USA Quote Link to comment Share on other sites More sharing options...
103west43rd Posted May 10, 2013 Share Posted May 10, 2013 Hello Tom. First, find a new dealer. They should have searched the TSB's to find out how to program the readout on the gauge cluster to display the clock. The clock display in the cluster depends on the radio that is installed. If you have a AM/FM factory radio (without CD), it is programmed to display the time. If you have the radio with AM/FM and CD (which I guess you do), it is programmed to display distance to empty. After your new dealer re-programs the cluster to show the time, the clock on your radio will not keep the correct time or date. That should not be an issue, as you wrote, you cannot see it. Quote Link to comment Share on other sites More sharing options...
