madlock Posted January 22, 2010 Share Posted January 22, 2010 I'm having a bugger of a time figuring-out the Accessories Hood Deflector. It would, at first blush, seem very straightforward; but there are a few items in the instructions diagram that I can't make sense of. The instructions are available here: http://www.fordaccessoriesstore.com/GfaWeb/getFileBlob.do?fileid=834 The specific steps I can't reconcile are 5 and 6. Step 5 depicts drilling-out the holes for the plastic mounting screws, but the second inset shows a second tool I just don't recognize. In step 6, there are two inset diagrams of either tools or hardware, one reading "PM-13-A", and another that seems to warn "no touch" for 5 minutes. I have no idea what either of these mean. If anyone could take a look and offer any suggestions, I'd greatly appreciate it. Thanks! Quote Link to comment Share on other sites More sharing options...
PetrosA Posted January 22, 2010 Share Posted January 22, 2010 I'm having a bugger of a time figuring-out the Accessories Hood Deflector. It would, at first blush, seem very straightforward; but there are a few items in the instructions diagram that I can't make sense of. The instructions are available here: http://www.fordaccessoriesstore.com/GfaWeb/getFileBlob.do?fileid=834 The specific steps I can't reconcile are 5 and 6. Step 5 depicts drilling-out the holes for the plastic mounting screws, but the second inset shows a second tool I just don't recognize. In step 6, there are two inset diagrams of either tools or hardware, one reading "PM-13-A", and another that seems to warn "no touch" for 5 minutes. I have no idea what either of these mean. If anyone could take a look and offer any suggestions, I'd greatly appreciate it. Thanks! The tool pictured in Step 5 is a de-burring tool. There's a blade in it which rotates as you ream the sides of the hole you drill and this removes the burrs left behind from drilling. You could use a fine-tooth round file instead. Google is telling me that PM-13-A is a Ford anti-corrosion product, which I would assume has a 5 minute dry-to-touch time. Hope this helps Quote Link to comment Share on other sites More sharing options...
madlock Posted January 23, 2010 Author Share Posted January 23, 2010 The tool pictured in Step 5 is a de-burring tool. There's a blade in it which rotates as you ream the sides of the hole you drill and this removes the burrs left behind from drilling. You could use a fine-tooth round file instead. Google is telling me that PM-13-A is a Ford anti-corrosion product, which I would assume has a 5 minute dry-to-touch time. Hope this helps Thanks. That turned-out to be the case. Ironically, 3 dealers I contacted hadn't a clue, and 2 tried to tell me it was something I knew to be wrong. Quote Link to comment Share on other sites More sharing options...
