madlock Posted December 26, 2009 Share Posted December 26, 2009 Reminiscent of my prostate, the rear passenger side washer stream suddenly stopped. After a quick visit to my local dealer who blew some air through the nozzle, it once again sprays but with a very weak stream. I seem to recall both sides working relatively equally well, so I'm not sure if the weaker right side is typical, or if it still needs repair. Any comparative observations would be appreciated. Finally, does anyone know if the nozzle is made to be removed by the integral hex bolt beneath the wiper arm mount? Thanks again Quote Link to comment Share on other sites More sharing options...
humitex Posted December 26, 2009 Share Posted December 26, 2009 Reminiscent of my prostate, the rear passenger side washer stream suddenly stopped. After a quick visit to my local dealer who blew some air through the nozzle, it once again sprays but with a very weak stream. I seem to recall both sides working relatively equally well, so I'm not sure if the weaker right side is typical, or if it still needs repair. Any comparative observations would be appreciated. Finally, does anyone know if the nozzle is made to be removed by the integral hex bolt beneath the wiper arm mount? Thanks again Mad, One thing I noticed while removing the rubber grommet from the back right door is water or washer fluid inside the rubber grommet..which is strange, which may indicate a leak. Also check behind the right rear light..when I removed it I noticed the hose was wedged between the light and the body of the truck..that may explain the weak results you are experiencing too. Hope it helps! Quote Link to comment Share on other sites More sharing options...
madlock Posted December 27, 2009 Author Share Posted December 27, 2009 Mad, One thing I noticed while removing the rubber grommet from the back right door is water or washer fluid inside the rubber grommet..which is strange, which may indicate a leak. Also check behind the right rear light..when I removed it I noticed the hose was wedged between the light and the body of the truck..that may explain the weak results you are experiencing too. Hope it helps! Thanks. Will do. I've also noticed the rubber sleeve that connects the wiring and other supply feeds from the body to the rear doors doesn't always rest securely between the two and sometimes gets pinched between the door and frame. Quote Link to comment Share on other sites More sharing options...
