Anyone running Ford Focus wheels (F1EZ-1007-A) on a 2021 Transit Connect?
andresito
Hey everyone,
I have a 2021 Ford Transit Connect and recently installed a set of 16x7 Ford Focus wheels (part #F1EZ-1007-A). They look great and fit fine in the rear, but on the front wheels, I’m getting rubbing on the inside of the wheel barrel, likely due to the larger front brake calipers on the van.
Has anyone else run into this issue?
  • Did you solve it with spacers (if so, what size)?
  • Or did you end up switching back to OEM wheels?
  • Any long-term issues if I keep running spacers?
Appreciate any tips or recommendations. Photos and part numbers would also help if you found a good solution!
Thanks in advance 🙌
— Andrés
