TC2014 Posted April 1 Share Posted April 1 Story Time Owner of a used 2014 Ford Transit Connect 2.5L Gas This morning go to start the vehicle, clearly hearing misfires on the idle. Van runs at reduced power, very shakey, and CEL/Engine Light flashing like crazy. Luckily because it is a Work Vehicle, I had invested in spare parts for standby in case of an emergency. Grabbed those spare parts and took them, had to drive off due to the timeframe. Once I got to a safe spot to do some work, I brought out a scan tool that indicated misfires all over the place and "Open to Ground" on all injectors and the Fuel Pump 8mm Socket to remove the bolts that hold on the Ignition Coils 5/8" Spark Plug Socket (3/8" drive) for removing the Spark Plugs Cylinder #2 Spark Plug was missing the pointed center electrode, all the remaining cylinders had significant corrosion and carbon buildup Cylinder #1 Ignition Coil was cracked and showing internals After replacing these parts, I started the van back up. Clean Idle, no knocks. Cleared errors with my scan tool I still got codes for "Open to Ground" on all the Fuel Injectors and the Fuel Pump, but that has been an issue since I have owned this vehicle. If anyone has insights into this particular issue, let me know what you found. Otherwise, problem resolved. Parts sourced from Rock Auto Ignition Coil: SKP SKUF621T Spark Plugs: NGK 90220 Ruthenium HX High Ignitability *probably overkill on the spark plugs but they were the highest rated on RockAuto and the price was reasonable at ~$12.60 CAD each* Hope this can be helpful to others. Quote Link to comment Share on other sites More sharing options...
