mikefordtransitconnect Posted February 20, 2024 Share Posted February 20, 2024 2015 connect 2.5l 6f35 trans I ripped the tss Turbine speed sensor connector off during trans removal I have a new connector but all the wires are the same color greening all 3 I have No way to tell what wires went were On the new connector I am considering the lock as the toofif you were looking at the pins in the connector directly [ ]lock ( O. O. O. ) 1. 2. 3. I have 3 wires on the original harness Brown- blue 0vdc 120ohms to ground White-orange 5vdc Green-violet 12.45vdc I need to know what color goes to what pin number as shown above Any help or even a picture of the schematic I also keep blowing fuse 33 in the fuse box under the hood on rightside right of battery box And I keep getting 6 codes when this happens P0420 bank 1 below threshold P0403 exhuast gas recerc cntrl circuit P0443 evap emmsns sys purge valve circ P0103 mass air high input P0135 bank 1 sens 1 P0010 intake can sens open bank 1 I assume these are all due to the fuse 33 blowing after I unhook the Turbine speed sensor the fuse stops blowing when I replace the fuse with out the tss plugged in it stays good and those errors no longer come on as soon as you turn the van on. I really think it's all because of this sensor and now that I have tested each wire I have found that 1 is ground 1 is 5v 1 is 12v so at this point I have no idea if I have hooked the 12v to the 5v or the ground at this point and I am wondering if that hasn't destroyed the tss by hooking it up improperly I have been to the deal for the wiring diagram and repair manuals for this thing and they tell me it's not availble at all and cannot find anything online I paid 100 for a repair program but it only has mechanical side nothing on electrical or diagrams at all so if anyone has a picture of there transit I'll i really need is to match color to pin I am going to get a new tss Turbine speed sensor And hopefully I can get some help in knowing which wire is to what pin # thanks for the help Quote Link to comment Share on other sites More sharing options...
