Stock Lug Nuts are horriable
15 hours ago, Bert Remington said:
I too switched to Black lug nuts (DPAccessories) although without a security key.  However the cone face was shorter than the stock lug nuts so I only torqued them to 120 lbft rather than stock 150 lbft.  What was your experience in this regard?
I used McGard, and same - cone was definitely shorter. I called McGard and confirmed I had the correct kit - which I did and they said its OK, as mine were designed for Alloy wheels only. Guessing the big stock ones work well with steelies as well (so I kept 5 stock lugs for the spare tire). I torqued mine to the specs in my manual, which was 100lb-ft (2014 TC).
Edited by dcommsc
