2010 TC air conditioner
Vonn
My air-conditioning hose line has a hole in it needs replacing. Is this a difficult job to do for myself? I’m near Port Angeles. WA   it seems pricey to pay professionals at auto shops.
Anyone out there replaced an air conditioning line
Not sure how difficult it is to replace the line, but a complicating factor is the entire system will need to have the air removed before replacing the refrigerant. Due to this complication, I don’t even consider working on AC. The need for special tools to connect a vacuum pump for pumping down the system always stopped me from my normal DIY approach.
disclaimer: it’s been many years since I tried AC work. Maybe things have changed.
A/C isn't as bad as some people make it out to be, but Chip is right that it takes special tools.
If you aren't empty from the leak, you have to go to a shop anyway to pull the refrigerant. If you are empty, you need line disconnect tools, manifold gauges, a can tap, and a vacuum pump. Legally, you're also supposed to have an EPA 609 license. On top of the line you're replacing, you'll need ~2 cans of new refrigerant and a new dryer, which has to be replaced when you open the system, plus a little bit of PAG oil to put in it.
If we say the line is $40, dryer $30, disco tools $15, gauges $50, pump $100, tap $10, new gas $20, oil $15, and license $20, you can call it $300 worth of shit to make it happen.
In a general sense, replacing a line isn't that difficult. Exactly what's in the way depends on which line you broke. The dryer (and the low-side port) are in the passenger wheel well, so you need to pull the liner to get in there, at least.
