bycycle Posted May 14, 2023 Share Posted May 14, 2023 FYI: if you want to remove the separation wall between driver compartment and cargo, you will need to remove the 2-seats-combo because of the missing head repository. then you need to remove middle seat belt as well. But it is connected as well to the airbag signal, which will light up, when disconnected. easy trick: add four 10 ohms in parallel to get about 3.4 ohms resistance. solved. ;-) Quote Link to comment Share on other sites More sharing options...
