DW2207 Posted February 16, 2023 Share Posted February 16, 2023 Hi there, thus is my first post so hoping I've got it in the correct place. OK so I have a 2018 L2 connect limited model(uk spec). It is pretty much fully loaded, sync 3, apple android play, rear camera and rear pdc sensors, cc. I'm fitting the front pdc sensors that I believe some owners opted for on the build sheet. So far I've got from fords Front wiring harness (adaptive cornering fog lights and 4 pdc plugs) P aid button. This also incorporates the stop start button. Below hvac controls. So far with forscan I've managed to activate the van graphics logo in top right hand corner of sync 3 screen with the pdc beacon graphics. Everything works fine from the rear sensors. Gridlines, steering lines all present. I'm just hitting a brick wall with regarding the activation of the fronts. Ive changed various blocks in the as built bcmii and apim but can not get the front sensors to code in. My pam is ft1t-15k866-bb. I have all 3 plugs plugged in to this. Pam from what I can find out will not let you change its as built on this platform. Can only make changes in the 2 modules I've referred to. Is there anyone who as this option able to share their pam part numbers, maybe some as built data on these modules? Van also as the 6 speed powershift gearbox if this makes a difference. Thanks Dan Quote Link to comment Share on other sites More sharing options...
