location of sensor
scott f
hello - new to the group - thanks for allowing me in - my daughter converted a 2012 Transit Connect and loves it - however it has started to run rough on idle - no fault codes - runs perfect otherwise just when idling - and the exhaust smells like fuel big time - i had a different vehicle with similar symptoms and changed out the MAP sensor to correct it - does this vehicle have a MAP sensor ? and if so do you know the location? - thanks in advance!
