GetTransited Posted May 12, 2025 Share Posted May 12, 2025 Did you finish the rear disc swap? Did the Focus spindles have the same bolt pattern to bolt onto the Mk1 axle? Do you have a part number for the Mk1 rear disc spindles? Did you consider the more commonly available Mk2 rear hub, spindles, breaks on a Mk1 axle?? Thanks Quote Link to comment Share on other sites More sharing options...
lowspeedpursuit Posted May 22, 2025 Share Posted May 22, 2025 (edited) I dunno if jdob is still around, but I bought an extra sheet of 1/4" steel, went back to work full time, and never really had time to work on it again. I never found an Mk1 Focus rear disc spindle; they're vanishingly rare. The Mk2 TC hubs don't bolt up either. The Euro Mk1 TC rear disc spindle part numbers are 2T14-4A493-AD and 2T14-4A492-BD, but they're insanely expensive imports and you need the Euro calipers as well. Basically you have 3 options: 1. Buy all Euro rear disc parts like jdob. Expensive, takes a long time, end up with calipers that can't be easily replaced when they fail. 2. Fab brackets to adapt some other Ford caliper and figure out the parking brake. 3. Swap in an entire rear disc axle. For my time at this point, I'd probably be asking if there's any reason (wms or spring perch width radically different?) not to just install an entire Promaster rear beam and be done with it. Edited May 22, 2025 by lowspeedpursuit Quote Link to comment Share on other sites More sharing options...
