Here is the post I did on the Transmission Change. The hardest part of this operation will be getting the TC Jacked up. Should be almost level . Remove the Under body dust shield . Look for the Drain Plug. 11 mm or 7/16 wrench. ] This style funnel will slide down into the Vent plug you just removed Put 3 quarts of fluid in [attacjpg] ] Run the TC for 5 to 10 minutes . Then drain the fluid again. Repeat this 2 more times You have Now used 9 quarts of fluid. Put t
