2016 shift problem
clancya
The transmission won't shift into gear even though the shifter does move.  The shift indicator on the digital display only shows when pushing the shift lever forward. The key only comes out if the shifter is pushed forward and held.  All brake lights work and the brake switch moves as designed.
Any ideas?
  • 9 months later...
