zepper
Front Wheel Bearings
Thanks for the info on the titanium, I will check into it.
The disc brake parts here in the northeast have other causes for shorter pad and rotor life.
On 3/18/2017 at 2:14 PM, Beta Don said:
Going to a wider tire on a wider wheel with a different offset would likely exacerbate the problem and not solve it  -  The load on the bearings would be much higher with a wider tire on a wider track wheel
But  -  The 'real problem' could be just the quality of the bearings themselves.  If you pay someone to do the change and they have a choice of a $40 bearing, a $70 bearing or a $100 bearing, guess which one they'll probably buy for you?  -  $400 for labor to install a $40 bearing isn't any bargain
www.rockauto.com lists 5 different wheel bearings ranging in price from about $40 to $117.00
http://www.rockauto.com/en/catalog/ford,2012,transit+connect,2.0l+l4,1501993,brake+&+wheel+hub,wheel+bearing,1672
Good info Don, thanks!  They mention a Timkin that is hearted.  Is the heart a recommendation?  Again thanks, I'll keep RockAuto in mind.
