How improve gas mileage
goco
. Most agree that under inflation will reduce gas mileage but there seem to be mixed results from over inflation. I believe you when you say it works for you. but others find that it does not help to go beyond the recommendations.
http://theframjak.hubpages.com/hub/tire-pressure-and-gas-mileage-does-it-really-matter
http://www.popularmechanics.com/cars/news/4199963
Physics is Physics, less rolling resistance = better gas mileage.
It was covered on an episode of Mythbusters and those guys tend to get pretty scientific in their testing.
If your looking to squeeze every drop of gas out of your tank you gotta be willing to try these crazy things ;)
Taking this discussion a slightly different direction...
There are two places where I buy 87 octane gasoline for my TC. Both locations are operated by the same company. One offeres a 10 percent ethanol blend 87, the other has zero ethanol 87.
I ALWAYS buy at the zero ethanol location because I get better mileage.
Time to change my air filter...
A major factor effecting mileage is traffic.  Sit in traffic with the engine idling, A/C on, and let the fuel burn.  If you can idle and burn a gallon of fuel per hour, how much fuel did you burn in an hour raveling 5 miles across town?
I tend to leave the engine on so that the A/C can keep the interior cool when I make stops.  If I'm inside for 10 or 20 minutes, then it's idling the entire time.
