Headlight adjustment
My headlights are pointed way too high. I cannot find the adjustment screws. I do see a hole in the corner brace. under it is a allen hole which when I turn it nothing happens. Know how to remove the headlight assembly buy how do you adjust it?? I will keep checking but please email if you can.
mgrant0606@aol.com
mgrant0606@aol.com
I can't answer your question, but I just wanted to thank you for LOWERING your headlights, rather than raising them to level with oncoming driver's eyes, as many shade tree mechanics seem want to do.
I Found it!!!!....it is the hole in the corner brace from the fender to the front. It is an allen hole that when turned adjusts the up or down of the head light. I was not using a long enough tool and could not turn it. I was using one of those fold out allen sets...
  • 11 years later...
