New key not recognized!
Following Procedure B on this website, I was able to program the buttons on a new key fob. However, the car does not start and the screen says something along the lines of key not recognized.
This is for a 2015 Ford Transit Connect.
Some background info: I bought a blank key fob on Amazon and had it cut locally. Mechanically, the key open my doors fine and the buttons on the new fob unlock and lock the doors as they should.
Has anyone come across this issue or could recommend me a working tutorial on this?
One issue may be the difference between the key fob security for operating the locks which I believe is just a coded radio signal, and the security key itself which I believe relies on a special chip inside the metal key itself. An aftermarket key may not have the chip in the metal key that will allow it to start the car due to the anti-theft not being satisfied, even if the signal from the plastic fob can unlock the door.
There is a seperate programming procedure for getting the Passive Anti-Theft system to recognize the security keys themselves that is seperate from just programming the fob to operate the doors. The following procedure is from my 2015 manual, starting on page 59.
"Programming a Spare Integrated Keyhead Transmitter You can program your own integrated keyhead transmitter or standard SecuriLock coded keys to your vehicle. This procedure will program both the engine immobilizer keycode and the remote entry portion of the remote control to your vehicle.
Only use integrated keyhead transmitters or standard SecuriLock keys.
You must have two previously programmed correctly coded keys and the new unprogrammed key readily accessible. See an authorized dealer to have the spare key programmed if two previously programmed correctly coded keys are not available.
Read and understand the entire procedure before you begin.
1. Insert the first previously programmed correctly coded key into the ignition.
2. Switch the ignition from off to on. Keep the ignition on for at least three seconds, but no more than 10 seconds.
3. Switch the ignition off and remove the first correctly coded key from the ignition.
4. After three seconds but within 10 seconds of switching the ignition off, insert the second previously correctly coded key into the ignition.
5. Switch the ignition from off to on. Keep the ignition on for at least three seconds, but no more than 10 seconds.
6. Switch the ignition off and remove the second previously programmed correctly coded key from the ignition.
7. After three seconds but within 10 seconds of switching the ignition off and removing the previously programmed correctly coded key, insert the new unprogrammed key into the ignition.
8. Switch the ignition from off to on. Keep the ignition on for at least six seconds.
9. Remove the newly programmed correctly coded key from the ignition.
If the key has been successfully programmed it will start the engine and operate the remote entry system (if the new key is an integrated keyhead transmitter).
If the key was not successfully programmed, wait 10 seconds and repeat Steps 1 through 8. If you are still unsuccessful, take your vehicle to an authorized dealer.
Note: You can program a maximum of eight coded keys to your vehicle. All eight can be integrated keyhead transmitters."
Edited by DonShockley
You need ALL the keys to the car in order to do this. Once you start the process, all keys in the sequence will be accepted and any keys not in the sequence will be eliminated.
I went through this with a '91 Dodge at work back in the day...
GK
Alas, I do not have 2 programmed keys. I bought the van used and was only given one of the keys since he lost the other. I really don't want to go to the dealership to program it but I'm also not in a rush so I'll keep looking for alternatives
In my area, the dealership subcontracts the work to a local locksmith.  There are locksmiths who have the software, hardware, and whatever else is needed to rekey and reprogram.  I don't know if that would be convenient to you.  In San Francisco, I would call a shop named Lock World.
Home » Auto
Automotive Locks, Keys, & Hardware
Lock World services the local San Francisco & Peninsula area with the following:
  • Keys made & duplicated
  • Doors & trunks unlocked
  • Locks replaced & Serviced
  • M-F 8:30am-5pm drive-in lock repair shop
    click here for our address, serviced areas, location, & map
  • Emergency road-side service available
 AAA Independent Contract Station
Lock World provides Advanced Automotive Locksmithservices. Lock World is the exclusive AAA (California State Automobile Association) locksmith for all of San Francisco and extending, including Daly City , South San Francisco , SFO Airport , and Burlingame . Lock World is the only locksmith shop to qualify for San Francisco County since the program was introduced in 1997!
Lock World’s facilities include a 3,000 sq ft drive-in shop where we service every type of domestic and foreign automotive key and lock. Lost keys, locked out, door locks and ignitions that are vandalized completely recoding all the locks on your vehicles, complete with computer-operated, machines, custom interiors, custom paint jobs and graphics. In our shop or on the road our radio dispatched service trucks are standing by. For your convenience we provide outstanding 30-minute 24HR emergency service. We stock the most complete collection of automotive key blanks and locks available.
New transponder hi-security locks and keys have been recently developed and introduced to the mechanical and electronic security of automobiles. Automotive locksmith skills are vital in servicing, re-keying, programming, and code cutting, these hi-security locks and keys.
With technology increasing most Car Keys are now micro transmitters called Transponder Keys.  These transponder keys not only need to be duplicated by computerized machines, but they also need to be programmed using a vehicle tech computer. If your vehicle is not on following list Transponder Keys it is a great idea to stop by Lock World to have plenty of spare keys made. With our same day service and customer parking you won’t have to worry about your keys any longer.
Now, very expensive transponder keys and locks are no longer $10.00 and $25.00 dollars. They are $60.00 keys, $90.00 remotes, $65.00 programming fees, and $100.00+locks! The procedure and costs involved with these new keys and locks are very expensive. To receive the best possible service for cutting, re-keying, duplicating, and repairing these keys and locks, you need a properly trained staff. This staff should be able to identify the simplest of problems (i.e. sticky locks, bad springs, worn keys, miss-cut keys, or just plain doesn’t look right) Sometimes the magic spray of oil goes a long way.
Lock World is the first automotive locksmith garage of it’s kind, the first AAA contract station, and first to invest in the automotive computerized key duplicating equipment and tech computers. With this development over the years, Lock World has become San Francisco’s hi-security automotive locksmith specialist.
Lock World is the most dealer recommended locksmith shop in the city. With these skills and relationships Lock World has developed, over the years feeds us with the most current knowledge and training available in the country. To the car dealer with the daily emergency lost keys, to the AAA emergency service call that comes in 24hrs a day…
Lock World is The Next Step
Hi-Security for Automotive
Transponder keys for foreign & domestic locks
Lock World is the first automotive locksmith garage of its kind, the first AAA station, and the first shop to invest in automotive diagnostic equipment and computerized key cutting machines.With this development, Lock World has become hi-security & advanced technology automotive lock specialists.
Beware: Your car may be on our list of automobiles that only locksmith should open. Click here, to find out if your car is considered highly difficult to open.
Lock World offers the following services Nationwide, as well as locally. Call today for information on opening account.
  • Programming, re-keying, & code-cutting
  • Keys by code delivered same-day
  • Data-base of all key codes ever published
  • Business accounts available, email or call today to open an account, (415) 221-4050.
24HR Emergency Service
(415) 221-4050
Copyright © 2010 - This Site - All rights reserved. Conforms to W3C Standard XHTML & CSS
Mine is a 2016, long wheel base wagon, in XL trim.  Basically what would be delivered into someone's corporate fleet, or part of the government fleet.  Cloth upholstery, rubber floors, AM/FM radio without SYNC, no fog or cornering lights, plastic interior.  No vehicle is truly stripped down anymore.  This one came with the useless mirror heater.  Useless to me, since I don't have snow to melt off the mirror.
On 7/9/2018 at 4:47 PM, Fifty150 said:
The seller supposedly lost the other key.
My Transit Connect came with 4 keys.  Is that the norm these days?
Yes, that is the norm going forward at least for the later model TC. They need a minimum of 4 keys registered vs the 2 keys you normally need for most of the other Fords.
  • 6 months later...
  • 4 months later...
  • 4 months later...
Car Locksmith Boca Raton technician has programmed keys and those keys are really working like the new ones.
