Do 15" steel wheels fit?
I'm looking for All-Terrain tires and the best option I found so far is Yokohama 205/70r15 98H they are only 4% larger compared to stock.
If 15" steel wheels fit over the front brakes does anyone know what vehicle I could get these wheels from used?
Or will 215/65r16 98H fit?  They are 6.7% taller
Or the last option because they do not have the rated weight rating 215/60r16 95H,
Edited by dinocarsfast
Here's a good place to check on wheel specs ...
https://www.wheel-size.com/size/ford/transit-connect/
The critical bits would be stud spacing (5x108), center bore (63.4), and wheel offset (52.5). Get close to those, and whatever wheel you select should work. It's my understanding that pretty much any Focus wheel will fit, but don't quote me on that.
