Sign in to follow this
DPL646
LED light bars for roof rack?
Im looking to get an LED light bar for my transit connect roof rack. Mounting on the front and possibly other LED lights for the rack on the back side. Any recommendations for all weather LED housings and lights?
Thanks
-David
I have installed a lot of different light bars sourced from Amazon.com.   Some have been better than others.
Currently, I like RigidHorse & AutoFeel.  Based upon what I see, most of these products are branded by different sellers, but come from the same factories in China.  Some have better pricing.  Some offer better product support and service.  I use these 2 brands because they use the same power supply wiring harness, which is remote operated.  Simply attach to battery under the hood, and connect to the light bar.  No drilling holes in the firewall and dashboard, no additional wire runs to install a switch.  A remote control key fob operates all of the lighting functions.  Lights can illuminate in white/daylight, and amber.  Lights can also be used as emergency lighting with flashing strobe patterns.  The obvious is that the bigger the light bar, the LEDs, the higher the amp draw, and you get a higher lumen output putting more useable light on the road.
https://smile.amazon.com/stores/node/11475974011?_encoding=UTF8&field-lbr_brands_browse-bin=Rigidhorse&ref_=bl_dp_s_web_11475974011
https://smile.amazon.com/AutoFeel/b/ref=bl_dp_s_web_10718189011?ie=UTF8&node=10718189011&field-lbr_brands_browse-bin=AutoFeel
Roll over image to zoom in
LED Light Bar Straight, Autofeel 22" 256W 8D Quad Row Spotlights Combo Beam Light bar Amber lamp for Truck Jeep ATV UTV Wrangler SUV Dodge Ram 4x4 Ford Golf
Price: $67.99 Free Shipping for Prime Members
  • LED Light bar Curved, AutoFeel 52" 8D Quad Row Spot Flood Combo Beam Lightbar Off Road Auto Work LED Light Bar for Truck Jeep ATV UTV Wrangler SUV Dodge Ram 4x4 Ford Golf
Price: $140.99 Free Shipping for Prime Members
Rigidhorse 8D Quad Row LED Light Bar
7 Inch LED Spot Light Light Bar Accessories
Combined use:7 inch with large size light bar use together (22 "32" 42 "52"), can make the lighting effect more significant
$1599Prime
8D Quad-Row Rigidhorse 22 inch
Quad Row Light Bar Design: The unique 4 rows of high density LED chips and 8D lens make sure the light will be much bright
$8699Prime
$5099Prime
$7999Prime
$9099Prime
$17099Prime
$4099Prime
$2999Prime
$7099Prime
