williaty
How do I re-enable window auto-up on a 2014?
As delivered, my 2014 would, from the driver's door control panel, run any window automatically all the way down if you pushed the button all the way down. Similarly, if you pulled the button all the way up, any window would auto-up all the way to fully closed. I had to disconnect the battery today and now the auto-down works but the auto-up doesn't.
Any idea how to reprogram it to do the auto-up function again? I can't find any section in the manual talking about this.
Although it is listed under the Bounce Back feature instead of the One-Touch Up feature, it does mention needing to reset after a battery disconnect and to repeat the procedure if the window does not close automatically. It probably won't hurt to try.
(From page 74/75 of my 2015 TC owners manual )
If you have disconnected the battery, you must reset the bounce-back memory separately for each window.
1. Lift and hold the control until the window is fully closed.
2. Release the control.
3. Lift and hold the control again for a few seconds.
4. Release the control.
5. Lift and hold the control again for a few seconds.
6. Release the control.
7. Press and hold the control until the window is fully open.
8. Lift and hold the control until the window is fully closed.
9. Release the control.
10. Open the window and then try to close it automatically.
11. Repeat the procedure if the window does not close automatically.
Thanks Don,
I found that same answer last night on a Fiesta forum. I fixed the van today but I forgot to come back here and post about it.
