Sign in to follow this
Bart Luther
anoying back up alarm sound
Found a way to stop that annoying sound when I put my van in reverse. I unpluged this connector and the sound has stopped completely . I know it was there to warn me about to back into something but because I added this adapter to my hitch for my bicycle rack the sound happened all the time .now I get a short warning on my Dash but no annoying sound in reverse. The audible warning is supposed to stop when you plug in trailer lights but that never worked for me so every time I back my boat down the ramp I hear the sound that I'm going to crash into something now its silent so I can concentrate on what I'm doing. the camera still works just fine
picture of hitch adaptor causing the back up alarm to make audible alarm constantly while in reverse
Is the trailer plug original? It should disable beeping if it senses the trailer plugged in.
no I bought a aftermarket Item By CURT The hitch and Plug and play wiring kit . Fits nice and trailer lights work fine but back up alarm is not disabled when plugged in .
I also have  the Curt trailer hitch and wiring kit, and as I have a raised ball mount to fit my trailer, I end up with a scenario very similar. My solutions are:
1 - Remove the ball mount if I don't need it; it only takes seconds to remove, and I don't like to bump into it.
2 - I have a switch to temporarily disable the alarm when I have the ball mount installed or when I back up with a trailer. (2015 XLT wagon). The switch leaves the camera active.
Nice ! I wish on the 2016 Titanium there was a parking alarm switch on the console . I would have defiantly used that option many times .
Well , I just went out to my van and sure enough I do have that button on my console I guess I just didn't know what it was thanks for the help I will have to pull the side panel back off to hook up the connector again and then I'll give it a try
Great to know! Been happening with my bike rack installed and good to know there's a simple work around :)
