4String
TC aftermarket wheels
These wheels are exactly the same dimension as stock.
16x6.5, 5x108, 50mm offset, 63mm center bore.
Just installed yesterday. Didn't want fitment issues, and wanted to keep everything within the sheet metal. They are painted aluminum,  made in Germany, 'rial' brand. They were $108 each, and came with lug nuts. Really happy with the look.
Nice and classic looking, a bit like blender blades.
I've just installed my new ones yesterday.
Unless they changed something for 2017, the stock wheel size is 16 X 7
The  stock 16 inch wheels are 6.5 wide.with a 50mm offset.
Any Picture's mrtn
Edited by G B L
mrtn: they DO look like blender blades! Too funny. Was actually my second choice. First choice set were going out of production, so I chose these. A fortunate change positive in my opinion.
Thanks for for the comments. Still looking for a rear wing (spoiler) that will fit. I've had no luck so far.
Tom
4 hours ago, G B L said:
Any Picture's mrtn
18121218_10212904317545237_7341539657480
Very nice .  Looks like you have Spring also.
Thanks. Will be in a week I hope. it's been dancing around freezing temps (with occasional snow) for a month now.
EDIT: it snowed in the morning and it's now changed into a full on rainstorm. Just got back from tieing suff down.
EDIT2: aaaand it's snowing again.
EDIT3: aaaand the studded tire use permission has been extended by one week (until 7th of may, normally due April 30th).
Edited by mrtn
Thanks for the tip on some Volvo wheels fitting our TCs.
Found a set of studded tires on some American Racing wheels in OEM/Volvo fitment on the cheap.  Swapped the studs to the factory steel rims and threw the contis on the alloys.
Looks sooo much better
Edited by stopbreakindown
Nice wheels Spooner, what brand and style are they?
