2016 TC Arm Rest Removal
Chumba
Does anyone know how to remove the driver side arm rest on a 2016 TC?
I'm trying to fit a motorcycle in the back of my 2016 TC and the front wheel (ever so slightly) pokes between the seats. Just enough for the arm rest to get in the way....
Figured it out!
Just rotate the armrest to a 60 degree angle and pull. Should slide right off.
If you are having trouble, try putting the armrest in the lowest position then (assuming your in the passenger seat) pull toward you while you rotate the armrest through its full range of motion. That's it!
4 hours ago, MLB said:
WHat gets you an armrest?  16 XLT with none.
I think the armrest comes attached to the seat on base versions when the center console doesnt have a padded surface.  My van is very basic and doesnt have much but the armrest is attached to the seat
  • 4 years later...
