Split back doors- What's that rectangular pop out on top outside of one door?
Campcrazy
Hmmm...can't figure out how to look at your gallery yet. New here. What did you do? I'm planning to use mine for camping so was thinking of using it for a micro fan ventilation duct. Is that what you did? I think that panel unscrews from inside of door with thumb screws like a tail light does donesnt it?
Hello Campcrazy. Just click on my name and then chose Gallery from the list on the left side of the screen. I originally bought the European third brake light to replace the roof mounted light. I decided against that idea and used it for a mount for a ham radio antenna. Yes, just unscrew it from the inside.
Hey like that ham mount! I might do the same thing for my portable cb radio's antenna. Either that or I'll use it as a fan ventilation port but I'd have to drill a hole in the inside back of the door for the air to flow through and I'd use a tiny fan with a mounting plate rigged up to match the existing thumb screws that hold the cover on. Fan would install inside of the tc door. A little screen across the drilled vent hole would keep mosquito's out when camping. When the fan isn't used I could just screw the factory cover plate back on.
Another idea for people would be to mount a light in that spot for outside lighting when camping or working behind the vehicle.
Looks like you bought a UK TC taillight and drilled through it to use as your mount? If I do an antenna rather than buying the lens I'll probably use a piece of thick rubber to mount and drill through. Don't want to drill out the stock cover in case I go back to that.
Edited by Campcrazy
