Ford Transit Connect Specifications
2010 Ford Transit Connect Specifications
BODY
Construction
Steel unibody
Final Assembly Location
Kocaeli, Turkey
POWERTRAIN AND CHASSIS
ENGINE
Type
2.0 Duratec DOHC I-4
Manufacturing location
Valencia Spain
Configuration
Aluminum block and head
Intake Manifold
Nylon (PA6 GF30)
Exhaust Manifold
Cast-iron
Crankshaft
Cast-iron
Redline
7000 RPM (intermittent)
Idle Speed in Drive
650 RPM
Throttle Body
Electronic
Valvetrain
DOHC, 4 valves per cylinder
Valve Diameter
Intake valve head dia 35mm, Exhaust valve head dia 30mm
Pistons
Die cast Aluminum
Connecting Rods
Powdered metal
Ignition
Electronic
Bore x Stroke
3.44 x 3.27 / 87.5 x 83.1 mm
Displacement
121 cu in. /  1999 cc
Compression Ratio
10.0:1
Horsepower
136 @ 6,300 RPM
Horsepower Per Liter
68
Torque
128 lb.-ft @ 4,750 RPM
Recommended Fuel
87 Octane
Fuel Capacity
15.1 gallons
Fuel Injection
Sequential multiport electronic
Oil Capacity
4.5 quarts with filter
Recommended Oil
5w20 (NA)
Emission Control
Three-way catalyst
ENGINE
Federal Standards
Yes
California Standards
Yes
DRIVETRAIN
Layout
Front-wheel drive
TRANSMISSION
Standard
4-speed Automatic transmission with overdrive
Gear Ratios
1st
2.82:1
2nd
1.50:1
3rd
1.00:1
4th
0.73:1
Reverse
2.65:1
Final Drive
4.20:1
SUSPENSION
Front
Front independent MacPherson Strut Suspension w/ stabilizer bar
Rear
Rear multileaf Spring Suspension w/ stabilizer bar
STEERING
Type
Power rack and pinion
Steering Column
Collapsible
Turning circle curb-to-curb
39 feet
BRAKES
Type
4-Wheel power front disc & rear drum Anti-Lock Brake system (ABS)
Front
Disc
Swept Area
N/A
Rear
Drum
Swept Area
N/A
Power assist
Yes
WHEELS AND TIRES
15” wheels with 6-spoke wheel covers
DIMENSIONS (inches unless otherwise noted)
EXTERIOR
Wheelbase
114.6
Vehicle length
180.6
Vehicle width (without mirrors)
70.7
Vehicle height at curb
79.3
Track width, front/rear
59.3/61.1
INTERIOR
Seating capacity
2, 4 or 5
Headroom
Front row
51.1
Second row
50.5
Legroom
Front row
40.5
Second row
38.5
Shoulder room
Front row
54.4
Second row
59.6
Hip room
Front row
50.8
Second row
59.8
WEIGHTS AND CAPACITIES (pounds unless otherwise noted)
Total passenger volume
132.1 (wagon)/65.1 (Van)
Cargo Volume Behind 1st  Row
135.3
Cargo Volume Behind 2nd Row
78.1
Maximum payload
1600 lbs
Base curb weight
FWD
3470
FUEL ECONOMY (city/hwy)
FWD
Pending EPA Fuel Economy Certification
  • 4 months later...
  • 4 weeks later...
