Bret1197
2014 radio issue
I have a 2014 tc that has a radio issue. Upon shut down and restart no sound comes out of the radio. It lights up and is on just no sound. It only happens maybe 20% of the time and if I shut the truck down and restart it comes back on and is fine. Anyone else have this issue?
Yes, I have had this issue, I told the dealer, and they have checked, can't seem to find any problem. They asked me to come by one day when it's not working, since when I have an appointment, it always is working fine. Of course, since that time, it's not been an issue.
my air conditioner used to do similar.
turn on van would never blow cold after 15 20 minutes, pull over side of road , shut key off turn back on and presto cold air .
hasn't done it for awhile .
my rear window wipers are whats acting up now . turn on key and the swipe across the window even when shut off . they do it once or twice then it doesn't happen again usually
the rears will sometime also come on by themselves when using the front intermittant wipers , even though the rear switch is off .
the day I picked up my new van it was raining and when I had the front wipers on and put the van in reverse the rear wiper did a single swipe, perhaps a safety issue. haven't gotten enough rain this winter to test again but perhaps what you're seeing is something similar.
Edited by windguy
If you have a rain sensor and you have some dirt on the sensor then it's normal they do a swipe or two. Rear single swipe on reverse is also normal.
My Radio doesn't come back on if I shut the vehicle down, then restart. It looks as if it's on, but I have to press it "Off" then press it "on" again, and it plays fine. My 2014 TC titanium is in the shop now, and they said they'd check......I'll report back if I hear anything helpful!
I am also having a strange radio problem some times while the radio is playing I get a popping noise then all speakers go dead if I stop and turn engine off then on radio comes back on happens at the strangest time also today when it happened the second time I had to reset the clock  and the day and date which idiot engineer added a day and date setting to the radio he needs a bitch slap
