jshelby861
Oil
The 2017 TC TELLS you when to change the oil based on your driving conditions. NO oil change interval is specified. In the past, I always changed mine spring and fall so I could do it in decent weather with no heated or weather tight garage.
If you use a quality filter, full synthetic 5W-20 and drive 10,000 miles per year or less, you can just change it once per year.  That's the 'schedule' we're using
I agree with Beta Don. Today's synthetics are really good, the additives don't easily break down. I use Mobil 1 5/20 full synthetic, change it every 7500 miles and use Motorcraft filters. It's easy and I change it myself, about once a year. Keep a eye on the oil level once a month and you'll never have an oil related engine failure.
They don't specify it with the introduction of maintenance minders.. I don't have one in the menu, so mine's set to 20,000 km (12,500 miles) or once a year. I change at 15,000 km (9600 miles).
The engines are still the same and the oils are still the same. Only extreme usage or climate conditions affect the oil change intervals to extremes.
The new full size Transits have 50,000 km (31,250 miles) service schedule over here. Absurd.
I suspect that  changing the oil too often was never the cause of early engine failure .  The extra cost of too many oil changes is minuscule in the total cost of a vehicle.
If the  drive-train warranty of the  EU transits is 100000 Km the oil change interval will not make a difference.  They will weld the hood closed soon!!
I agree  -  The cost of the oil itself and the filter is minimal.  It's the moron they hire to change it who leaves the drain plug loose, or under or over  tightens the filter (or neglects to change it at all) or leaves the oil filler cap off the engine
The more often you need to have someone work on your car, the higher the probability one of them will screw something up
True story  -  My daughter took her car to the dealer for an oil and filter change and they left the filler cap off.  About the time she got home and shut the car off, she noticed smoke rolling out from under the hood.  A check showed she was a quart low.  Then, the dealer had to keep the  car two days to steam clean everything.  Better I guess than the finger tight drain plug stories I've heard so many times where all the oil runs out
I think the manufacturers realize that if your first service isn't due until after the warranty expires, there's much less chance one of their 'technicians' will screw something up which would require a new engine under warranty!
I haven't been to a dealer except for a warranty recall in 45 years.
I haven't either  -  Done 100% of all my maintenance myself, to include brake jobs, timing belts and everything else.  But . . . . I had *hoped* when we bought our TC that I would just take it in and let the dealer do everything  -  I'm getting too old to enjoy crawling under cars!
Unfortunately, my first trips to the two dealers closest to the house turned out to be very unpleasant experiences.  The first one charged me a 20% ($30) 'restocking fee' to return an accessory I had ordered which arrived broken  -  The box it came in had been opened and retaped shut half a dozen times before we got it, so pretty obvious this broken piece had been 'restocked' before
Took it to a second dealer for a warranty issue and also had them check on the rear wiper which wasn't working when we bought the car.  Took them a week to get the passenger window to roll up and down correctly and then they hit me with 'Fuses are not warranty items'.  They wanted a $99 'diagnostic fee' for changing the fuse.  When I asked why I needed to pay $99 to have a fuse changed, they said they needed to find out WHY the fuse blew out.  Why did it blow?  'We don't know  -  We replaced it and it didn't blow again'
I'm not the sharpest knife in the drawer, but even for me it's pretty easy to figure out that neither of these dealers want or need my business, so I guess I'm not retiring my ramps any time soon.  I'm coming up on my first oil change at 20,000 miles (Van had 13K when I bought it) and then the 13 quart transmission fluid change at 25,000 miles
I will make sure all the drain plugs are reinstalled correctly, and the oil filler cap too!
MLB    1
On 4/20/2010 at 2:58 PM, madlock said:
http://www.motorcraftservice.com/pubs/content/~WOATRC/~MUS~LEN/40/10frdmg2e.pdf
I know the TC Owner's Manual and Service Guide recommends 5,000 miles miles and using Motorcraft Oil (which is a synthetic blend), I impose a 3,000-mile regimen with Mobil 1 (Always) on EVERY vehicle I own, and I've NEVER regretted it.
It also goes one hell of a long way to bolster value if selling to a private party.
You're wasting oil that could easily go 4 -5 times that mileage.
